Oct 1st, 2024, 2:18am
A question about 4th-order LPF in CP-PLL (Read 3137 times)
SemiLeon
Jul 13th, 2007, 7:22am
Hi, all,
I have a question about the design of 4th-order loop filter for charge-pump PLL. Dean give a method to design a loop filter by given pole ratios. In dean's method, the poles of the filter are all on the real axis, but I think it is possible to design a filter with a pair of complex pole, and It may have better attenuation.
Please give me some advise.
Thanks and best Regards.
boe
Re:  A question about 4th-order LPF in CP-PLL
Reply #1 - Jul 16th, 2007, 12:49am
Hi Leon,
If you use a complex pole pair to improve the attenuation, you are very likely to make the phase response worse.
So I expect you'll find it very hard to get a PLL with 4th-order complex-pole loop filter stable (especially over PVT & mismatch).
BOE
SemiLeon
Reply #2 - Jul 18th, 2007, 5:34am
Hi, BOE,
Thanks for your reply.
I think if the two highest frequency poles are made complex pair, the stability problem may be less grievous. I just want to find a way to design a passive loop filter with a pair of complex pole, and do some experiment. It may be better than we thought.
Leon
boe
Reply #3 - Jul 23rd, 2007, 12:51am
Hi Leon,
Let me know what you find out. I'm very interested in it. Didn't ned it yet, though...
BOE
