Oct 1st, 2024, 12:15am
breakdown voltage (Read 3382 times)
nxing
God help the person
who help themselves
China
breakdown voltage
Jul 23rd, 2007, 2:45pm
Hi everybody,
I have one question regarding the breakdown voltage for CMOS, say if I am using a 0.18um device (with power supply 0.18v for VDD), can I have my Vgs (or Vgb) exceed 1.8V, for example, I have the DC bias at 1.5V and the input sin wave with Vamp=0.5v?
HdrChopper
Re: breakdown voltage
Reply #1 - Jul 23rd, 2007, 6:21pm
Hi nxing,
One concern regarding the gate voltage is with the gate-body oxide breakdown voltage. This is usually the one that breaks down first in standard CMOS processes. Depending on the oxide thickness this breakdown voltage might change its value. For reference, typically tox of about 1e-8m can have breakdown voltages of 5-7V.
Hope this helps.
tosei
Keep it simple
Berti
Reply #2 - Jul 23rd, 2007, 10:27pm
Hi nxing, tosei
I agree that the junction breakdown voltage is quite high (5-7V, maybe even more). Your vgb can therefore
be higher than 1.8V (but leakage will increase!).
But for the gate-source voltage it is more critical. For long-term reliability fabs often limit the supply voltage
tp +10% (<2V in your case). However, if you don't care about reliability the maximum vgs can be larger without
leading to unrecoverable failure for minimum gate length devices. Fabs specifiy this voltage to about +40% which
would be 2.5V for 0.18um. Any higher supply (dc) voltage will be on your own risk...
