Aug 17th, 2024, 5:26pm
ON The Designer's Guide to High-Purity Oscillator (Read 5885 times)
jlee
Jul 15th, 2007, 1:22am
Hey Guys,
Have you read the book "The Designer's Guide to High-Purity Oscillator"? What about this book? Is it really helpful to optimize phase noise of VCO?
Could you please give me your comments on this book?
Thanks!
rfmems
Re: ON The Designer's Guide to High-Purity Oscilla
Reply #1 - Jul 15th, 2007, 4:38am
I have to say, there are quite a number of mistakes in this book.
neoflash
Mixed-Signal
Designer
Reply #2 - Jul 15th, 2007, 5:35am
Author is going to upload a errata list. However, I'm not sure about the time.
Basically, it follows Abidi style. Make those complicated problems in simple and intuitive way. This gives u a lot of qualitve preview of LC-tank.
jlee
Reply #3 - Jul 15th, 2007, 6:52am
Thank you, Chenyan and neoflash.
Actually, I have read the papers on optimizing phase noise by Emad Hegazi, Jacob Rael & Asad Abidi.
I just wonder whether there are other tricks mentioned in this book.  If so, I plan to spend some time going through this book.
I am really puzzled in the design of LC-tank based VCO.
rfmems
Reply #4 - Jul 15th, 2007, 8:12am
Even I said there are some mistakes in the book, I still recommend you to read the book. There is not many tricks in the book except the noise filtering you alread read, however, it still provides you some insight on phase noise and LC VCOs. But be caeful of the deductions. Also, I would recommend you to do some pxf simulations when you read along. Just to get impresions how each noise source contributes to your phase noise.
jlee
Reply #5 - Jul 15th, 2007, 7:05pm
Thank you, chenyan.
I have already used filtering such as choke inductor for 2nd harmonic rejection. But, when I select the choke inductance, I just run Pnoise to estimate whether I have used the right incutance for optimized phase noise.
Is there any other way to confirm the choke inductance such as PXF, PAC?
If so, could you please give me more detailed anaysis  method?
Thanks!
rfmems
Reply #6 - Jul 16th, 2007, 7:20am
Hi Jlee, be aware of the parasitic caps on the node you connect your inductor. This will shift the resonate frequency of your noise filtering.
jjrael
Reply #7 - Jul 16th, 2007, 10:01am
This is Jacob Rael. I am planning on releasing an errata here in a about a month. I am having some friends review the text to see if I caught all the errors.
Also, I used PXF to find that the noise from the current source was carried on the 2nd harmonic.  The easiest thing to do is add a 0 amp current source in parallel with your current source transistor and use PXF to simulate the gain from the current source to the output voltage. As long as you divert the 2nd harmonic to ground, the performance should not be too sensitive to the inductor or cap values. However, flicker noise is another beast...
jr
jlee
Reply #8 - Jul 16th, 2007, 9:08pm
Thank you, chenyan and Rael.
Also, I have noticed that the parasitic cap on the source of negative gm transistors has impact on the filtering effect.
Actually, 2nd harmonic filter can be used to improve phase noise in 1/f^3 regiion. But I found it is really sensitive to the choke inductance and cap on that node.
Rael, could you please give some comments on how to design the 2nd harmonic filter based on 1/f^3 phase noise improvement, especially how to choose the choke inductance?
