Aug 17th, 2024, 5:17pm
How to measure a varactor's capacitanc (Read 3731 times)
Tim
Jul 10th, 2007, 4:06pm
Hi, All experts
I am a beginner in RF design. I am doing VCO. Does anyone know how to
measure a varactor's capacitance (i.e. capacitance v.s. frequency) in cadence?
Someone told me I could use S-Parameter to measure it. But I still can't  get it.
Anyone can tell me in detail. Thanks
Tim
topquark
Thames Valley, UK
Re: How to measure a varactor's capacitanc
Reply #1 - Jul 12th, 2007, 4:25am
Hi Tim
first off, you can already see the cap you're setting in the schematics, right?  :D
For MOS varactors, you specify the W/L  and you can see the cap value
well, cap vs. freq will be constant but impedance vs. freq is what you're looking for..uh?
If you go by S-parameters, you can get Zin/Zout as function of frequency 'n then calculate cap.
Or, simply run an ac sim with a standalone varactor 'n you can characterize Cap vs. voltage bias which will be required for your VCO tuning.
Hope this helps
neoflash
Mixed-Signal
Designer
Reply #2 - Jul 15th, 2007, 5:41am
u should notice that in LC-tank, the capacitance matters is not small-signal capacitance, instead, it is the large signal averaged capacitance.
jlee
Reply #3 - Jul 15th, 2007, 7:01am
If small signal SP is performed, use the following equation to get C vs freq curve with the calculator in Spectre.
C=imag(y(1,1))/2/pi/xval(imag(y(1,1)))
Maybe more accuracy results can be obtained by PSS+PSP.
