Aug 17th, 2024, 5:16pm
MOS sizes in RF Design (Read 3181 times)
eng
USA
Jul 12th, 2007, 12:16pm
Is it necessary to use minimum length for an RF circuit. i.e. LNA. I doubled both length and width of my LNA (Lmin=0.18um) there is a .6 dB NF improvement and -5 dBm P1dB improvement. Gain dropped 4.5 dB. The transient results look good. I don't know if I'm missing a important point.
What are the consequences of increaing L in RF design?
James Bond
Re: MOS sizes in RF Design
Reply #1 - Jul 12th, 2007, 12:40pm
do you have the same current when increase the size ?
eng
USA
Reply #2 - Jul 12th, 2007, 1:43pm
current increased only 23u. It was 795u became 818u.
aaron_do
Reply #3 - Jul 12th, 2007, 6:45pm
It depends on your system. If your system has a high NF requirement, then 0.6 dB NF won't make a dent in the overall system NF. 4.5 dB gain however might be very important.
ACWWong
Oxford, UK
Reply #4 - Jul 13th, 2007, 2:20am
eng wrote on Jul 12th, 2007, 12:16pm:
My thoughts are as follows:
Increasing L will decrease ft of the device and increase capacitance, although cgs is usually matched out. This doesn't really matter if the input gm transistor is operating at 0.1*ft anyway and in cascode configuration. The cascode device however, which develops the voltage gain, may suffer from larger L as a consequence of lowered ft means less gain available.
Obviously if current and W are not changed, overdrive increases which means less gm, but more linearity.
But mostly your choice depends on your specifications as Aaron_do said. I must admit the CMOS LNAs i have designed (few hundred MHz to few GHz) have seldom need minimum geometry (expect at >~0.35um), also having larger L might help ESD robustnbess as well.
cheers
aw
