Oct 1st, 2024, 6:26am
Feedback Factor (Read 5838 times)
joeb
Feedback Factor
Jul 16th, 2007, 12:40am
When I use the y-parameters to modelize the integrator, I got a feedback factor equals to sCf (Cf for feedback Capacitance).
However the feedback is in reality given by:
f=Cf/(Cs+Cs+Cp)
I ask myself from where comes formula (1) and why feedback factor got by the y parameters method is inexact?
Thanks for your answers.
Best Regards
joeb
Re: Feedback Factor
Reply #1 - Jul 16th, 2007, 12:41am
Sorry I made a mistake:
f=Cf/(Cf+Cs+Cp)
Cs : Sampling capacitor
Cp: Parasitics capacitor
qiushidaren
I am a lovely
MOSFET!
Chengdu
Re: Feedback Factor
Reply #2 - Jul 16th, 2007, 9:14am
Hmmm, I think a figure will be helpful for us to understand your question well.
-Terry
joeb
Re: Feedback Factor
Reply #3 - Jul 18th, 2007, 12:58am
You asked me for a figure.
Thanks for ur answers
HdrChopper
Re: Feedback Factor
Reply #4 - Jul 18th, 2007, 7:55pm
Hi Joeb,
The formula you mentioned can be derived considering the clock phase is such that Cs is connected to the OTA´s input and assuming a linear small signal model for the OTA.
You can consider the feedback network is such that you are feeding back a voltage signal VI' = VI'+ - VI'-, which is the OTA´s differential input signal. If this is the case, then the feedback factor will be the transfer function given by VI'/VO (for VI=0). Considering this transfer function the feedback factor is readily deduced as the voltage divider between Cf and the parallel combination of Cs and Cp (or Cin in your figure):
VI'/VO (VI=0) = [1/s(Cs+Cp)] / [1/s(Cs+Cp)+1/sCf]  = Cf/(Cf+Cs+Cp)  (1)
Now, the feedback network can also be considered as connected in series with the input of your controlled source (OTAs linear model), or in other words, it feeds back a current.
Since the output signal for your feedback network is now a current, the y parameters apply and you get -1/Zf, where Zf=1/sCf. Here the feedback factor is given by II'/VO @ VI=0, where II' is the differential input current coming out of the feedback network.
However, the INPUT signal to your system now must be a current and not a voltage. Such input input current can be found as:
VI/ZI, where ZI= 1/s(Cs+Cp).
Thus
VI' = VI-I×ZI = VI+[(VO-VI')×sCf]×1/s(Cs+Cp).
If VI=0 you get VI'/VO=[1/s(Cs+Cp)] / [1/s(Cs+Cp)+1/sCf]  = Cf/(Cf+Cs+Cp) , which is the same as (1)
So it is not that the y-parameters are wrong, it is just that you were considering different feedback networks when comparing the formulas. Therefore, the feedback factor will depend on what you consider is your feedback network and your input variables, but both must give you the same overall results.
Tosei
Keep it simple
joeb
Re: Feedback Factor
Reply #5 - Jul 19th, 2007, 2:57am
Hi Tosei,
Thanks for your answer Wink
joeb
Re: Feedback Factor
Reply #6 - Jul 19th, 2007, 4:53am
I would like to note that in the book of Kennet S Kundert " The designers guide to Spice and Spectre" they note that the feedback factor is given by f=y12 ( p.89) when we talk on Y model parameters shunt shunt feedback. ( This is the same definition given in Razavi's Book).
So in  my switch cap circuit case (shunt shunt feedback) I got  f= -sCf.
But in the reality we have f=Cf/(Cf+Ci+Cp).
How we have to considerate this f ? as a feedback factor impedance?
HdrChopper
Re: Feedback Factor
Reply #7 - Jul 19th, 2007, 2:04pm
Hi Joeb,
I would consider it that way. The reason for that is what I suggested before: if you consider the feedback network to output a current signal, the admitance model (y-parameters) applies (the currents are controlled by input/output voltages)  and f=y12=-sCf (note that to calculate the voltage transfer function you will have to convert that output feedback current into voltage. Now, if you consider the feedback network to output a voltage, then the impedance model is what applies (the voltages are controlled by input/output currents).
If you apply that model you should get f=f=Cf/(Cf+Ci+Cp).
Tosei
Keep it simple
HdrChopper
Re: Feedback Factor
Reply #8 - Jul 22nd, 2007, 4:18pm
Hi Joeb,
I kept thinking about this and I think there also another way to look at it.
When using y-model for determining the feedback factor, you are using the two-port model for describing the feedback loop. If this model is used, your feedback factor will depend on the type of input/output variables (and therefore on the two-port model you have to use).
On the other hand, the feedback factor you mention as f=Cf/(Cf +Cp + Cs), can be derived from the Return ratio feedback model: breaking the loop at -say - the OTA inputs you will find the feedback factor is the one you were asking about.
There is a good paper about return ratio vs two-port model you can look at that might help: "A comparison of two approaches to feedback circuit analysis", Paul J. Hurst - IEEE Transactions on Educations - Aug 1992
Tosei
Keep it simple
