James Bond
Hi, aaron_do,
You are quite right, and you know exactly what I am talking about. That's true, I can use two resistor to connect between + and - input, with the ground connecting to the middle of the resistors, but this will load the mixer, usually , we want capacitive load instead of resistive load. Could you suggest me any ideas ? Any comments would be appreciated. Thank you very much.
James
