vivkr
When realizing a successive approximation type of converter, one often uses a capacitive DAC. The limitation here is usually mismatch, particularly due to the large variations on the smallest caps which are 2^N times smaller than the largest ones, and the standard method is to choose a large enough unit element cap, but this gives too much capacitance => more power.
From time to time, people talk of using multiple unit caps in series to realize the smaller caps in the C-DAC. For instance, an 8-bit C-DAC may have 16 unit caps in parallel for the largest element and 16 unit caps in series for the smallest one (to exaggerate, as this would still not be a good solution).
How does one control the intermediate high-Z nodes now? There will be several problems including charge-deposition during the ion etch process on these plates. If one were to tie a reverse-biased diode to these plates, then the leakeage current of these would wreak havoc at these high-Z nodes.
Is there a way around?
Thanks Vivek
