May 3rd, 2024, 12:45am
Pages: 1 2
Multi-thread Circuit Simulator (Read 4545 times)
John O Donovan
San Jose, CA
Re: Multi-thread Circuit Simulator
Reply #15 - Sep 25th, 2007, 10:16pm
On the subject of crashing, could you provide some more details, such as the version of Spectre used, when the crash occured, what type of models are being used, etc ... Multi-threading of device evaluation, while not simple, is not fundamentally very complicated, and should not lead to any crashes since by the time devices are being evaluated, all required memory is allocated, hence no memory related issue should exist.
 John
JoRobins
Give and it shall be
given unto you!
San Diego, CA
Reply #16 - Sep 29th, 2007, 7:58am
Andrew Beckett wrote on Aug 27th, 2007, 1:52pm:
To reply to the original question, Spectre from Cadence has multithreading capability, both for device model evaluation, and also in the harmonic balance engine in SpectreRF.
Just a quick comment on my experience with the multithreading option in spectre. Typically for a top level PLL sim transient sim (>500 devices?), a colleague and I  saw a speedup of about 2x on a 4-core CPU machine using the multithread option. I remember that for extracting the max. benefit out of multithread sims, Cadence had some recommendations like not to have current probes inserted and such... The spectreRF shooting engine based pss does not use the multithread option which is a bummer.... I'm yet to warm up to the harmonic balance version...
byang
Reply #17 - Sep 29th, 2007, 11:56am
Hi, Jorobins,
2x speedup on 4-core computer is kind of low. This is especially true if device model evaluation of a simulator is slow. In that case, device model evaluation should benefit a lot from multi-threading. (Current probe can add more nodes in the circuit, which causes the circuit matrix to become bigger and slower to solve. Unfortunately matrix parallelization is much harder to do.)
The best next-generation multi-threaded circuit simulator should have:
* fast device model evaluation and yet high multi-threading efficiency
* efficient parallel matrix solver
which covered the two most important areas in circuit simulation: device model evaluation and matrix solving.
Baolin Yang, Ph.D.
Founder and President
Gemini Design Technology, Inc.
www.gemini-da.com
IainC
Reply #18 - Aug 8th, 2008, 6:31am
I'm really quite doubtful that a mixed signal design could be simulated faster multi-threaded.
Given that it's transient you would likely lose as much time synchronising at each timepoint as you gained in parallel processing - not to mention the major headache you would have if the results of one process affected the (on-going) calculations handed to another thread. e.g. something in the circuit switches.
Not an expert in this by any means but I can't see for a typical design how this could be made to work.
schehrazi
University of CA, LA
Reply #19 - Sep 9th, 2009, 5:35pm
Reply #20 - Sep 12th, 2009, 12:53am
4x speed up on 4-CPU computer for Corner Analysis in ADE. Smiley
schehrazi
Reply #21 - Sep 12th, 2009, 1:21am
That's different though since the corner simulations are independent of each other. If one gets 4X speed up in transient simulation on a 4 CPU machine, that will be something.
Reply #22 - Jan 4th, 2010, 1:09pm
I'd quite forgotten about this thread, and things have moved on a lot since it started.
Cadence's APS simulator (which is essentially a mode of spectre) parallelizes both the device evaluation and matrix solve, and does a number of other things to get large speed improvements without compromising accuracy; some of which is the result of having an improved matrix solver - so we see speed improvements even on single core. Don't want to make this a sales pitch, but if you're already using spectre and are unaware of APS, it's worth contacting Cadence to find out more. It's in use by a lot of happy users now...
It was introduced in MMSIM71, and in MMSIM72 APS is extended to most of the analyses in spectre, including the RF analyses.
schehrazi
Reply #23 - Jan 4th, 2010, 1:26pm
Thank you Andrew. I have heard of the APS but have never tried it. I will give it a try and will let you know of my experience if I have it installed.
Pages: 1 2
