Aug 17th, 2024, 7:21pm
antenna error (Read 2524 times)
aaron_do
antenna error
Jul 20th, 2007, 12:10am
how does changing the metal layer fix the antenna error problem? i.e. changing back and forth between metal lines...
thanks,
Aaron
didac
There's a million
ways to see the
things in life
manresa,spain
Re: antenna error
Reply #1 - Jul 20th, 2007, 12:19am
Antenna effect is caused during the etching of the metals. The track "captures" ions that go to the gate oxide. Breaking the track and going one metal up during a short space and the going down again will prevent this effect.
Hope it helps,
didac
There's a million
ways to see the
things in life
manresa,spain
Re: antenna error
Reply #2 - Jul 20th, 2007, 12:29am
Hi again,
I was thinking that I don't really answer your question. If you think how the IC is fabricated you will see that the foundry maka one layer at time(first ion implantation, then heat to growth...), referring to metals first you have metaln after the etch the oxide growth and you have metaln+1. So if you have a track made in metaln and you break it to prevent antenna, during etching it will atract ions but when the ions arrive at the break they won't find a path to continue because your bridge in metaln+1 will not be fabricated yet.
Hope it helps,
