Sep 30th, 2024, 12:17am
current source design (Read 4723 times)
filipe
Brasil
Jul 20th, 2007, 2:21pm
I'm desingning an operational amplifier, and I'm implementing a current source with a MOS transistor M1.
All the projects that I have seen have a small length to M1, probably due to the matching, I think.
But if I have a big L to M1, I have a greater impedance to the current source, and this is good. What
should I do??? Why dont use a big L???
View Profile filipe filipe   IP Logged
aaron_do
Re: current source design
Reply #1 - Jul 21st, 2007, 12:33am
Is M1 the input transistor (with all the gm)? If so then the small L gives higher Gm*BW since cgs is smaller for the same aspect ratio(W/L). Large L gives better matching, output resistance, and potentially better noise performance.
filipe
Brasil
Reply #2 - Jul 23rd, 2007, 9:59am
The M1 is the current source, as shown in the figure.
Why should I use a small L to it?? Why don’t use a big L to M1 and MB?
joeb
Reply #3 - Jul 24th, 2007, 1:16am
When u use small  L values , you have the benefit of low Vdsat. This is low power constraints.
It's clear that u have trade offs with matching
Sid
Reply #4 - Jul 24th, 2007, 3:46pm
Your M1 current source should have a large L for better output impedance. However, if you make L of M1 large you limit your input common-mode range (since now M1 has a large vdsat, your PMOS inputs will need to have a lower input common-mode for M1 to be in saturation). The high output impedance of M1 will improve your input common-mode rejection (CMRR). So, it is a trade-off between input common-mode compliance (i.e. range) and CMRR.
-Sid
Monkeybad
Reply #5 - Aug 2nd, 2007, 7:04pm
Why not? The current source will become more ideal with large L.
Besides, I'm wondering that why the large L will affect the Vdsat and the input common mode voltage.
If you keep the Vgs of M1 the same, then you can still have the same Vdsat of the M1 for the saturation.
But now the current of M1 is lower when you increase the L, so you can increase the W to keep the
same current. Isn't it? (It's just my thought and correct me if I'm wrong.)
BEST REGARD
doho
Reply #6 - Aug 5th, 2007, 4:58am
Monkeybad wrote on Aug 2nd, 2007, 7:04pm:
BEST REGARD
Yes, you are absolutely right. The drain-source current is proportional to W/L and the output resistance to 1/L, so by increasing W and L with the same factor you can achieve a higher output resistance. But a larger transistor also has higher capacitances, so the effective output capacitance of your current source will increase. If you do not expect to have any voltage swing at the output node of the current source, then the extra capacitance will not matter. But if you expect large voltage swings at high frequenies, it might actually degrade the output impedance. A larger transistor also takes up more area which might be valuable. Summarizing you can say that, increasing W and L with the same factor for the output transistor in this current source results in higher output resistance, larger area and larger output capacitance.
« Last Edit: Aug 5th, 2007, 6:15am by doho »
