Aug 17th, 2024, 5:19pm
Max. Vds for 3.3V pMOS in 0.18um CMOS process (Read 3534 times)
Terence
CAD Lab.
Taiwan, R.O.C.
Jul 22nd, 2007, 10:24pm
I would like to operate 3.3V pMOS of generic 0.18um CMOS process in the following conditions.
Bias: Vds=5V ; Vgs=3.3V ; Vsb=0 ; Vb=0
Size: W/L = 20/0.3
Is there any realibility or punch-through issue?
Thanks.
Terence
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Max. Vds for 3.3V pMOS in 0.18um CMOS process
Reply #1 - Jul 26th, 2007, 7:33am
Of course there are reliability issues: you're using the device outside it normal operating conditions. The process design guidelines should be able to tell you what the maximal Vds is at which most devices will break down.
Consider also that you are putting a field of 5V/0.3um = 1.67e+07 V/m across the channel. You might expect some HCI issues, I would say. I presume this is the minimum length for a 3v3 compliant PMOS device?
What could be worse is that the model parameters are not valid in this operating region - that really depends on the characterization procedures for the given device. Again, the documentation of the process should be able to give you the details.
krishnap
Reply #2 - Aug 1st, 2007, 11:14pm
usually foundry datasheet will have the maximum volage that can be applied for the device.
so that the device will operate within the safe reliability limits.
Also the time duration for which the device is connected to the higher voltage. For shorter time it is ok.
Another way is to have devices in series so that Vds is distributed, when higher volatge need to be applied.
