Aug 17th, 2024, 3:23pm
How is Vth defined? (Read 2995 times)
fran2k5
How is Vth defined?
Aug 07th, 2007, 8:04am
Hi everybody,
recently I was performing some simple simulations of a single device in a 0.25um technology.
I wanted to check the variation of Vth with L keeping the same W.
I was quite surprised to notice that Vth decreases for longer transistors.
Could anybody help me out to interpret such results? I believe that the behavior should be opposite...
To check the Vth I use the "op" function of the calculator. How is this Vth defined? Does it correspond to the BSIM one?
Thank you very much,
fran2k5
vivkr
Re: How is Vth defined?
Reply #1 - Aug 7th, 2007, 11:10pm
Hi Frank,
Does the Vth first increase when you increase the channel length, and then start to fall off after a certain point?
If yes, then you are seeing reverse short channel effect. If not, then I could not say what the cause might be.
Try searching for reverse short channel effect on the web for more.
Vivek
fran2k5
Reply #2 - Aug 8th, 2007, 5:38am
Thank you Vivek.
I believe you are right. It seems that RSCE is predominant.
The fact that the short-channel effect is evident in the sub-threshold Ids-Vds curves does not really mean that the threshold voltage has to decrease.
frank
