Sep 30th, 2024, 6:29pm
Mismatch of Resistors in Resistor string DAC (Read 961 times)
hchanda
Jul 25th, 2007, 6:25pm
Hello All,
I am trying to understand how mismatch in resistors would affect the performance of resistor string DAC.
Suppose if the DAC assures the voltage range between V1 and V2 , will mismatch between the resistors affect the voltage range?
Is it going to affect the DAC step size and linearity?
I would like to get a clear picture of how mismatch between resistors would affect the resistor string DAC performance?
Appreciate your time.
hc
boe
Re: Mismatch of Resistors in Resistor string DAC
Reply #1 - Jul 26th, 2007, 4:41am
Hello hchanda,hchanda wrote on Jul 25th, 2007, 6:25pm:
Is it going to affect the DAC step size and linearity?...
Voltage range and (nominal) step size are unaffected by mismatch, as they are defined by the voltages at the end of your R string and the number of unit res's. Monotonicity is also structurally guaranteed.
Mismatch results in INL and DNL.
BOE
topquark
Thames Valley, UK
Reply #2 - Jul 26th, 2007, 4:58am
In general, in order to appreciate the effect of spreading of R-values on the monotonicty of the DAC, you have to rely on monte carlo sims.
Run a mc analysis as you switch from one R value to the next bit.
See the distribution of voltage or current or gain you're interested in.
As you go from nth bit to (n+1) th bit- smaller the spread, the better. Foir e.g
μ(n) + 3σ  should be < μ(n+1) - 3σ
Hope this helps.
hchanda
Reply #3 - Jul 26th, 2007, 10:55am
Thanks a lot BOE and Topquark.
hc
