Sep 5th, 2024, 4:26am
Is the eyediagram OK for the system applications? (Read 3614 times)
dandelion
Jul 26th, 2007, 12:32am
Would you pls. take a look at the attached three eyediagrams?
Eyediagram1 is a normal eyediagram. But eyediagram2 and diagram3 shows the crosspoint of the eyediangram shifted from midpoint seriously, especially for the eyedianrgram3, the crosspoint even disappeared. I checked my design spec, for the rise/fall time it is OK. And for the another spec of PWD(pulse waveform distortion), although the crosspoint of the eyediangram2&3 shifted seriously, they also meet the PWD spec because of the sharp rise/fall edge.
I wonder if the eyediagram2&3 is indeed OK for the system even they meet the design spec?
Thanks in advance
Dandelion
Re: Is the eyediagram OK for the system applicatio
Reply #1 - Jul 26th, 2007, 2:49am
What is it in eyediagram 3? The eyediagram 2 looks very bad. Is it 010101... ? Generally a mask is defined for the serial data communication like USB, IEEE 1394 .... You should check whether the waveform violate the mask.
Yawei
dandelion
Reply #2 - Jul 27th, 2007, 10:11pm
Is there any more comments,pls.?
