I used PSS shooting to simulate IP3(mixer) at given input level, IM3=-70dB
I also use PSS flexible balance to simulate IP3 at the same given input level, with oversample factor =4, I got IM3=-80dB.
I tried to use QPSS flexible balance to verity the IP3, I found out there is no oversample factor. I got the same IM3=-70dB
What is the best way to get the accurate IP3? what is the right number for oversample factor?
mindy
