May 19th, 2024, 3:23am
IP3 using pss/qpss (shooting and flexible balance) (Read 2134 times)
m
Jul 27th, 2007, 3:58pm
I used PSS shooting to simulate IP3(mixer) at given input level, IM3=-70dB
I also use PSS flexible balance to simulate IP3 at the same given input level, with oversample factor =4, I got IM3=-80dB.
I tried to use QPSS flexible balance to verity the IP3, I found out there is no oversample factor. I got the same IM3=-70dB
What is the best way to get the accurate IP3? what is the right number for oversample factor?
mindy Smiley
Re: IP3 using pss/qpss (shooting and flexible bala
Reply #1 - Aug 10th, 2007, 7:16am
Hi.
Try to plot both Pout and Pim3.
Check wheter Pim3 curve is gradient of 3dB/dB.
