May 18th, 2024, 11:14pm
the wide input voltage range in dc-dc converter (Read 8273 times)
feiyue
Jul 28th, 2007, 4:43pm
hi all,
I find that many commercial dc-dc converter product can tolerant wide input voltage range,such as 2.7v to 20v.I am curious that why they will not induce reliability issue for the controller and power transistors. For example,if we design the converter using 0.35um cmos technology,the nominal operation voltage is 3.3v,but if the operation voltage is 4.5v or higher,then the gate oxide of the digital circuits in controller and power transistors will break down. I am not sure whether my concern is correct.Does anybody have some ideas or explanation on it?  I wish my question would not be too simple.:)
Faisal
Re: the wide input voltage range in dc-dc converte
Reply #1 - Jul 30th, 2007, 7:23am
In some process technologies there are more than one version of transistor. E,g there are Thicker oxide transistors (in addition to normal oxide transistor) which can stand higher gate voltages. Some fab processes offer transistors for high voltage applications e,g 32V etc.
If your process does not has such transistors.. then I think it would not be possible to design such a wide range dc_dc converter in such a technology.
Kind Regards,
Faisal Mateen
feiyue
Reply #2 - Jul 30th, 2007, 10:24am
hi Faisal,
Thanks! if the input voltage is not so wide such as 3-5v,is it  a good solution to implement a internal linear regulator  to set a proper power supply for contrller IC ? then i think it maybe possible. I am not sure whether it is true.
vivkr
Reply #3 - Jul 31st, 2007, 2:35am
Hi feiyue,
Sure, you can use a linear regulator for getting a fixed internal supply. Just keep in mind the additional design overhead, power consumption,
and the drop introduced by the regulator.
If your controller really needs a constant, ripple-free supply and you have no constraints on power consumption and/or have external components
available for filtering your supply (assuming ripple from controller), then it may work well for you. Usually though, it is advisable to design your
controller to be relatively insensitive to supply, especially if the supply does not vary much, as you say.
Vivek
feiyue
Reply #4 - Aug 1st, 2007, 10:06pm
hi Vivek,
thank you very much for your suggestion!
feiyue
edwintsu
Reply #5 - Sep 11th, 2007, 4:53am
I have a similar question.
If the min. voltage range become lower , such as 1.8V, how to deal with it typically? (At corners of some process the sum of VTHN + |VTHP| is larger than the min. voltage.)
Use voltage boost circuit (charge pump) + voltage regulator to set the fixed internal voltage?
Thank you.
Edwin
jordan76
Truth always lies in
the details.
China
Re: the wide input voltage range in dc-dc converter
Reply #6 - Nov 27th, 2008, 11:41pm
Hi edwintsu.
In this case using voltage boost circuit (charge pump) + voltage regulator can be an option; often buck-boost converter can be better choice depending on your system spec: space, cost and efficiency etc.
Truth always lies in the details Smiley
regards,
Jordan76
regards,
Jordan76
View Profile jordan76   IP Logged
