Aug 15th, 2024, 12:02pm
is there an equivalent in VerilogA for wait statem (Read 3363 times)
sylak
Silicon valley
Jul 30th, 2007, 4:02pm
I am trying to replace some VHDL-AMS code with VerilogA, Here is a piece of code I want to replace... I cant think of any operation that can replace "wait" (in VHDL) in Verilog-AMS..
loop
   wait for quarPeriod;
   state_90 := not state_90;
   CLK90 <= state_90 and powerdown;
end loop
Re: is there an equivalent in VerilogA for wait st
Reply #1 - Jul 30th, 2007, 5:16pm
use
@(timer(...)) begin
sylak
Silicon valley
Reply #2 - Jul 30th, 2007, 6:37pm
Ken,
Thank you for the reply
I am generating a (oscillating) clock signal using the loop signals which inverts the CLK90 everytime.. Can I use a "forever" statment to substitute for the 'loop' statement? More importantly can it be used inside an "analog begin"
What is the syntax for such a statement?
Reply #3 - Jul 30th, 2007, 7:05pm
Take a look at the fixed frequency oscillator model in http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf.
You don't need any kind of loop statement at all. That is not the way the analog section works. It is run on every time step. So you instead you use @(timer(...)) to avoid executing statements that update the state of the model except at the desired points in time. So you would using something like ...
@(timer(next)) begin
     state = !state;
     next = next + period/2;
V(out) <+ transition(state);
