Jul 25th, 2024, 10:22pm
diode-connected NMOS's equivalent resistance issue (Read 5259 times)
trashbox
Aug 01st, 2007, 12:39am
Hi guys,
When I was deriving a formula from a simple circuit, I run into the diode-connected NMOS's equivalent resistance issue. The details are:
In the attached figure, the formula Vref1=(1+R1/R2)Vgs1-Vgs2 is obvious for the left circuit when two NMOSs M1/M2 are both in saturation and sink the most of current because of large R1 and R2. However, if using diode-connected NMOS M5/M6 instead of the passive resistance, I can not derive the Vref2 from the right circuit. The simulation shows the formula for Vref2 is right. Would you please give me any advice?
P.S., If I use 1/gm5=R1 and 1/gm6=R2 to derive Vref2 from Vref1, the result is not correct. I think 1/gm is a small-signal resistance and here the equivalent resistance should be a DC resistor.
boe
Re: diode-connected NMOS's equivalent resistance i
Reply #1 - Aug 1st, 2007, 2:21am
Hi trashbox,
The gm is indeed a small signal parameter; for your circuit you need the large signal resistance R = VDS / IDS(VGS).
BOE
trashbox
Reply #2 - Aug 1st, 2007, 2:53am
Hi Boe,
Yes, you are right. Thanks for your reply. I have solved this issue now. Smiley
Best wishes,
Trashbox
hande.vinayak
BOM
Re: diode-connected NMOS's equivalent resistance issue
Reply #3 - Mar 25th, 2011, 3:02am
Hi trashbox and boe,
   Even after substituting R = VDS / IDS(VGS), I could not get the final expressions for Vref2 as shown in above figure. Please, can you share the method to solve the problem?
Thanks.
Reply #4 - Mar 25th, 2011, 1:13pm
Why not just run a DC bias curve and take the resistance from the slope of the line?
