topquark
Thames Valley, UK
Hi folks,
I need to run a parasitic-extracted netlist simulation. I ran Calibre PEX on the layout view of the top-level cell and on the sub-blocks inside the hierarchy, generated the 'calibre' views for all the blocks. Then, I create a test bench schematic and config view to run my simulation. When I use 'calibre' view for the top-level cell, the simulation runs with the full-extracted netlist.( the sub-blocks inside top-level cell automatically are instantiated as 'calibre' views I believe) Now, I need to use block-by-block extratced views to see which block is adding critical parasitics. So, I turn on 'schematic' view for ther top-level cell and try to use 'calibre' view for one of the sub-blocks.
I get error during netlist generation:
here's the attached snapshot of the error
NOTE: I have DRC/LVS clean sub-block cell views and symbols match schematic in pins, wonder why pins are not being recognized during netlisting.
