vivkr
Hi Frank,
Does the Vth first increase when you increase the channel length, and then start to fall off after a certain point? If yes, then you are seeing reverse short channel effect. If not, then I could not say what the cause might be.
Try searching for reverse short channel effect on the web for more.
Regards Vivek
