Aug 15th, 2024, 12:11pm
Multi-tone signal sources in ADS (Read 3647 times)
asb1211
Aug 08th, 2007, 7:10pm
I have designed a logamp simulated with single tone source as input signal (ADS software).
Logamp is originally a peak detector used for continuous wave RF power measurement.
I wonder, in case input signal is multi cariers or others (CDMA, WCDMA, EDGE, GSM,...), can I still use logamp with some offset tuning for the output? (Some logamp from Analog Device states to be able to measure RF power of all above signal types)
Further more, anyone knows how to simulate those kinds of signal source multitone-wise in ADS, plz show me the way.
Thanks alot.
Re: Multi-tone signal sources in ADS
Reply #1 - Aug 9th, 2007, 2:19am
Hi.
You mean log-envelope detector ?
If so, logamp is applicable for such signals.
But some cresto factor compensation is needed for accurate power measurements,
for example, see data sheet of AD8313 from ADI.
There are many ways for such purpose in ADS.
For example, use V_nTone component which is valid for not only HB-Ana but also Transient-Ana.
Practical example are available in examples/Com_Sys/CATV_prj.
Or simply use signal sources in "Souce-Modulated", where various predefined moudulated signal sources such as GSM, DECT, CDMA, etc. are available.
« Last Edit: Aug 9th, 2007, 11:34pm by pancho_hideboo »
asb1211
Reply #2 - Aug 16th, 2007, 7:48pm
pancho_hideboo wrote on Aug 9th, 2007, 2:19am:
Hi.
Thank you very much pancho_hideboo for your reply.
When using "source-modulated" signal source, selecting CDMA for instance, how can I have different frequency allocations for simulations? Those sources are almost non-modified except for only frequency and power.
What if I want to compare in case of same channel power but 4, 8, or 16 sub-carriers?
Hope to hear more from you.
Again, thanking you for your help.
Reply #3 - Aug 16th, 2007, 10:53pm
CDMA(IS95) is direct sequence spread spectrum modulation which doesn't have
sub carrier but equivalently it can be expressed by multicarrier which amplitudes and phases
are random.
If you would like to express cdma signal by multicarrier, use V_nTone component.
Or your "same channel power but 4, 8, or 16 sub-carriers" means code multiplex ?
« Last Edit: Aug 17th, 2007, 2:14am by pancho_hideboo »
