Hi.
> Logamp is originally a peak detector used for continuous wave RF power measurement. > I wonder, in case input signal is multi cariers or others (CDMA, WCDMA, EDGE, GSM,...), > can I still use logamp with some offset tuning for the output?
You mean log-envelope detector ? If so, logamp is applicable for such signals. But some cresto factor compensation is needed for accurate power measurements, for example, see data sheet of AD8313 from ADI.
> Further more, anyone knows how to simulate those kinds of signal source multitone-wise in ADS, > plz show me the way.
There are many ways for such purpose in ADS. For example, use V_nTone component which is valid for not only HB-Ana but also Transient-Ana. Practical example are available in examples/Com_Sys/CATV_prj.
Or simply use signal sources in "Souce-Modulated", where various predefined moudulated signal sources such as GSM, DECT, CDMA, etc. are available.
