Aug 17th, 2024, 5:21pm
Buffer design for Passive differential mixer (Read 2765 times)
sandman
Aug 13th, 2007, 4:24am
Would anyone have literature on the design of a buffer at the output of a passive double balanced mixer (with no DC voltage available at the output of the mixer as part of a zero-IF receiver) ? Any help would be appreciated.
Cheers!
aaron_do
Re: Buffer design for Passive differential mixer
Reply #1 - Aug 13th, 2007, 7:41am
I'm not sure about any papers, but one way to do it would be something like this...
                      ----------output
                  __|
LO-----||----||__
             <       |-----||-----input
   Rlarge <       |
              |       > Rlarge
        Vbb+Vth  >
                     Vbb
where Vbb is the buffer biasing voltage and then you gotta do the whole double balancing and of course design the buffer. Note that you should be able to put Vbb and its Rlarge on the other side too.
sandman
Reply #2 - Aug 14th, 2007, 5:05am
Thanks aaron_do.
I think the one you've shown below is an LO buffer. I was looking for one that's used to interface the passive double balanced mixer with an off-chip measurement equipment. Would you know more abt it ?
Cheers !
aaron_do
Reply #3 - Aug 14th, 2007, 5:46pm
i think you've misread me. Sorry for the confusion, that's supposed to be a switching transistor for your passive mixer. i.e you have to use 4 of those transistors in a double balanced mixer. The bias Vbb will go through the switching transistor and allow you to bias your buffer.
cheers,
Aaron
