Aug 17th, 2024, 5:17pm
3 dB SNR lose when use 1-bit quantizer? (Read 1543 times)
liu6747
Portland, OR
Aug 14th, 2007, 2:28pm
Hi, All
I am reading Thomas Lee's RF book. On section 19.6.1 (2nd ed, page718), he talked about GPS receiver architecture, which is  RF to Low IF (IQ). The themal noise is about ~ 20 dBc higher than GPS signal at RF input, but GPS siganl has 43 dB process gain. The last stage is two 1-bit quantizers, and note 18 says:
Use fo a 1-bit quantizar costs 3 dB, relative to an infinitely fine quantizar. The most commonly used 2-bit quantizar, combined with appropriate AGC to maximize use of the available quantization levels, reduce the loss to about 0.7dB....
I assume the loss is about SNR, but should it be 6dB? because SNR_ADC=1.76+6N?
Please let me know where I am wrong and let me know how to calculate 3 dB on 1-bit adc
thanks
liu
« Last Edit: Aug 14th, 2007, 4:21pm by liu6747 »
carlgrace
Berkeley, CA
Re: 3 dB SNR lose when use 1-bit quantizer?
Reply #1 - Aug 15th, 2007, 10:31am
Lee was talking about power, not voltage.  So the 3dB power and the 6dB voltage are the same thing.
Carl
