Aug 17th, 2024, 7:26pm
Which Bits in Bluetooth EDR Mode Determing 2M or 3 (Read 1815 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Aug 13th, 2007, 11:59pm
In Bluetooth EDR mode where are the control bits which control whether the data rate is 2M or 3M?
Best regards,
Terry
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Which Bits in Bluetooth EDR Mode Determing 2M
Reply #1 - Aug 14th, 2007, 6:27am
Hi Terry,
I haven't worked with Bluetooth for a while but if you look at the specs in page 40 it tells you wich bits of LMP indicate each mode, also in page 390 you have the mask of the LMP PDU.
Hope it helps,
