Sep 17th, 2026, 9:01pm
Pages: 1 2
Simulation of DJ using SpectreRF (Read 30279 times)
Frank Wiedmann
Munich, Germany
Re: Simulation of DJ using SpectreRF
Reply #15 - Jan 13th, 2020, 12:48am
Select the node of which you want to analyze the performance. Usually, that's probably the output node.
dnw
Reply #16 - Feb 13th, 2020, 1:59pm
Hi Frank,
I am trying to setup a ring oscillator followed by a driver for supply senstivity analysis.
Both oscillator and driver share the same supply.
If I give 10mVp(20mVpp) 5MHz ripple on the supply then in transients sim I see a variation of 150fs peak(300fspeak-peak around 370ps nominal)
I tried replicating the same with pss + pxf analysis based on your previous posts
So in pss I choose the following
Enginer: Shooting
Beat Freq : fosc(1/370p)
output harmonics(No of harmonics) : 20
Oscillator: ticked
case1:
Osc Node+ : Driver out
Osc Node- : gnd
case2:
Osc Node+ : Terminal inside ring oscillator
Osc Node- : gnd
Pxf settings
sweeptype: default
Relative harmonic: 0
Freq sweep : 10Hz - 200MHz
Sidebands: Max sidebands: 1
case1:
Pos output node : Driver out
Neg output node : gnd
case2:
Pos output node : Terminal inside ring oscillator
Threshold = Vdd/2
Max Samples (Have tried blank and 2000 getting the same results with both)
I am trying to interpret the results I get out of these sims. As mentioned above I have two sims with pxf
case 1: one with a output of final driver selected for pss and pxf
case 2: one with a node inside the ring oscillator selected for pss and pxf
I am measuring the voltage gain @ 5MHz offset from the oscillation frequency
I get different gains for both cases
case 1: Gain of 6.5V/V
case 2: Gain of 10V/V
Even if one of them is right with 30GV/s dv/dt I get peak dt of 3.3ps with 10mVp which is almost 20 times more than what I am measuring with transient.
Could you please help me in figuring out where I am getting this wrong.
Thanks & Regards
« Last Edit: Feb 14th, 2020, 8:18am by dnw »
Frank Wiedmann
Munich, Germany
Reply #17 - Feb 14th, 2020, 4:24am
The PXF frequency is the frequency of the power supply ripple, so you should look at the result at 5MHz (which isn't even inside your sweep range right now).
dnw
Reply #18 - Feb 14th, 2020, 6:48am
Hi Frank,
Sorry for the confusion i am sweeping from 10Hz - 200MHz
I looked at 5MHz the gain is even higher 50
Which also does not look right.
Frank Wiedmann
Munich, Germany
Reply #19 - Feb 14th, 2020, 8:52am
I don't see any obvious problem with your setup. This has worked for me pretty well in the past, but I have not run this kind of analysis for quite some time and I also did not run it on oscillators back then. I suggest that you contact Cadence Support to let them sort this out, other people are currently also having problems with this kind of analysis (see https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/43477...).
dnw
Reply #20 - Feb 14th, 2020, 10:23am
Thanks, Frank I will try following up with them
Also, I was reading PSRR_OSC_AN.pdf from the spectreRF Workshop folder.
There they suggest using modulated instead of sampled for power supply sensitivity analysis. Just trying to understand the difference.
Thinking about this I think any perturbation on the power supply is kind of causing phase modulation around oscillation freq.
Pages: 1 2
