Aug 17th, 2024, 12:22pm
bondwire inductance matching (Read 2114 times)
aaron_do
Aug 23rd, 2007, 5:58am
how well matched are bond wire inductances? For example, if i have a differential LNA and each half needs a separate bondwire inductance, how good is the matching? Also, how accurate is the absolute value of the bondwire?
thanks,
Aaron
ACWWong
Oxford, UK
Re: bondwire inductance matching
Reply #1 - Aug 23rd, 2007, 9:57am
bonder repeatability is excellent, landing points are typically +/-10um, and looping is very well controlled.
matching other than this will depend on your bonding diagram and pin-out/leadframe. For well matched bondwires of course you must pay attention to these (critical high frequency differential pads on the middle of the die/package sides are best because they are short and less exposed to ESD events).
Modelling can be complicated by adjacent (adjacent +1, +2 etc. as well depending on land pitch), so a good em simulation of bondwires and package is needed.
