Sep 26th, 2024, 2:57pm
voltage follower speed (Read 1595 times)
cktlife
Aug 28th, 2007, 8:51am
Dear all,
It is known that DAC speed is limited by OPAMP if there is a voltage follower as a buffer at the output. The voltage follower reaches UGBW due to unity feedback. How fast can voltage follower operate?
carlgrace
Berkeley, CA
Re: voltage follower speed
Reply #1 - Aug 30th, 2007, 1:11pm
It really depends on the technology.  The voltage follower will operate the fastest of any feedback circuit because it has the lowest gain (and therefore the largest feedback factor).  It is possible to design a follower without an op amp if you have the headroom, this may be faster.  Also, if you have a current mode DAC you can try loading it with a resistor.  This is probably the highest speed you can do in a given technology.
