I am trying to set-up a simple simulation to understand trade-offs between different integrated inductors and varactor combinations in a LC tank.
I wrote a netlist containing one ideal L , one ideal C and one ideal R in parallel. In addition I put a negative resistance element with current limiting, to make an oscillator, and I run a spice transient analysis.
The netlist is the following,
**** circuit
.param Fosc=1G
.param Per_osc='1/Fosc'
.param twopi='4.0*asin(1.0)'
.param Wosc=twopi*Fosc
.param indvalue=10nH
.param capvalue='1/(indvalue*Wosc**2)'
.param vosc_max=2V
.param Imax=0.1mA
.param resvalue=10K
Gnres op on VALUE='-Imax*tanh(100*V(op,on))'
Losc1 op 0 'indvalue/2' IC=Imax
Losc2 0 on 'indvalue/2' IC=Imax
Cosc op on capvalue IC=0
Rpar op on resvalue
.param simtime='500*1/Fosc'
.param simstep='1/Fosc/10'
**** simulation
.tran simstep simtime uic
**** outputs
.probe tran I(Gnres) I(Losc1) I(Losc2) I(Cosc) I(Rpar)
.probe tran v(op,on)
.measure tran average(v(op,on)**2/resvalue) * average power dissipated on R
.measure tran max(v(op,on))**2/2/resvalue * avg power dissipated on R, assuming sine wave
.measure tran average(v(op,on)*I(rpar)) * avg power dissipated on R, yet another way
.measure tran average(v(op,on)*I(Gnres)) * avg power delivered by negative R element, NOT EQUAL TO THE ONES ABOVE!?
.end
This simulates fine, I see the tank voltage building up and stabilizing. Now, I am trying to figure out the Q of this tank circuit from the simulation results, and I'm totally confused!
If I compute the ratio max(I(Losc1))/max(I(rpar)) I obtain 156 , and it "should" be the Q of the tank...
If I calculate it as Q = resvalue/sqrt(indvalue/capvalue) I obtain 159.15, which is close, so theory and "practice" are hand in hand for now.
On the other hand , if I calculate Q = twopi*Fosc*Etank/Power where Etank= (capvalue/2*(max(v(op,on))**2)) and Power is the power dissipated obtained using one of the measure statements above I get values between 176 and 190 for Q, depending if I use the nominal
oscillating frequency of 1GHz or the actual one of 995.2819936583MEG , and also depending on which power dissipation measurement I take, absorbed by rpar or delivered by Gnres (6.8457E-05 or -7.2551E-05) .
Which one is the *true* Q of the tank, for phase noise optimization purposes ?
![Undecided Undecided](https://designers-guide.org/forum/Templates/Forum/default/undecided.gif)
Is there a fool-proof way to extract the Q of a LC tank , preferably looking only at V(op,on) and at the negative resistance current ?
Can anyone teach me the basics of Q-extraction from large-signal transient simulations ?
P.s. I don't have spectrerf, but I don't see how PSS would help me very much here... I'd like to hear your advice about it anyhow, please.
