Aug 17th, 2024, 2:22am
question about the analog comparator (Read 2209 times)
James Bond
Aug 28th, 2007, 1:20pm
Hi, all
I am trying to build an anolog comparator in 0.35um process.  I suppose that this comparator can operate at high frequency, for example, a 100MHz triangle wave form and 30MHz sinusoid signal at the input. But the result seems that the comparator in 0.35um process is not that sensitive at this frequency, can anybody have done this before ? Please give some suggestions about how to build this comparator? Thank you very much.
James
carlgrace
Berkeley, CA
Re: question about the analog comparator
Reply #1 - Aug 30th, 2007, 1:02pm
You can design a really fast comparator in 0.35 um.  The fastest would be a cross coupled latch, if you can accept the large offset voltage.  Otherwise use a latch with a linear, low gain amplifier in it.  See the Razavi book on data converters for ideas.  Also check out the JSSC.
James Bond
Reply #2 - Aug 31st, 2007, 2:22am
Hi, carlgrace,
I think the cross coupled latch circuit they all need a clock signal, which is not the case in my circuit.
I checked the Razavi book, which chapter do you mean 'data converters'?
James
