Sorry for unburying this old thread, but I have this exact issue.
I'm trying to simulate the static behavior of a DAC with a DC analysis, using an ideal ADC to provide the digital input for the DAC. I'm using the following VerilogA ADC (from the Verilog-A examples on this site):
Code:module adc(out, in, clk);
// parameter integer bits = 8 from [1:24];
`define bits 8 // resolution (bits)
parameter real fullscale = 1.0; // input range is from 0 to fullscale (V)
parameter real td = 0; // delay from clock edge to output (s)
parameter real tt = 0; // transition time of output (s)
parameter real vdd = 5.0; // voltage level of logic 1 (V)
parameter real thresh = vdd/2; // logic threshold level (V)
parameter integer dir = +1 from [-1:1] exclude 0;
// 1 for rising edges, -1 for falling
input in, clk;
output [0:`bits-1] out;
voltage in, clk;
voltage [0:`bits-1] out;
real sample, midpoint;
integer result[0:`bits-1];
integer i;
analog begin
@(cross(V(clk)-thresh, dir) or initial_step) begin
sample = V(in);
midpoint = fullscale/2.0;
for (i = `bits - 1; i >= 0; i = i - 1) begin
if (sample > midpoint) begin
result[i] = vdd;
sample = sample - midpoint;
end else begin
result[i] = 0.0;
sample = 2.0*sample;
generate i (`bits-1,0) begin
V(out[i]) <+ transition(result[i], td, tt);
`undef bits
In an DC analysis, the output of the ADC is all low, no matter what the input voltage is. By adding a $debug output, I can see that the analog section/initial_step is only run once (with in=0V), but not for each subsequent DC operating point.
I'm using Cadence/Spectre to simulate. How can I force Spectre to run the analog section / trigger the initial_step for each step?
Spectre Version:
12.1.1.164.isr15
