Sep 4th, 2024, 12:14am
current steering logic(CSL) buffer (Read 7683 times)
dandelion
Sep 03rd, 2007, 11:54pm
In the mixed signal design, to reduce the di/dt noise, CSL(current steering logic)attract more and more attention.
I am not familar with the CSL and I want to know is there any mature product of mixed mode IC used this technique which ahve replaced conventional static inverter?
Visjnoe
Re: current steering logic(CSL) buffer
Reply #1 - Sep 4th, 2007, 10:53am
Dear,
read any decent paper on SerDes RX/TX (PCI Express, SONET, XAUI...) and you will find lots of implementation examples.
Peter
dandelion
Reply #2 - Sep 4th, 2007, 6:39pm
Visjnoe wrote on Sep 4th, 2007, 10:53am:
Dear,
Peter
Hi,Peter,
Thanks for the reply.
I guess you mean the CML logic( current mode logic). Here, my question is I need the CSL logic buffer to replace the oringinal static inverter buffer(CMOS level). So, the requirement is critical for the low power, high driver capability. I found the Vol and Voh spec of my CSL logic implementing cmos level is  not good as static inverter, especially it would be worse when the load sink or source some current. Although its di/dt noise is indeed excellent, I wonder if any product use this technique to implement a CMOS level.
Dandelion
email_gz
gaoz.mail@gmail.com
Reply #3 - Nov 11th, 2007, 9:50pm
Hello all:
       I think current steering logic(CSL) buffer  is just CML. Except CML Driver, maybe Voltage Mode Driver can be used for lower power, but this type of driver is hard design becasue of Z match,and often have small output swing. AMD HT3 IO-link use Voltage Mode Driver with current mode Channel-Pre-Eq.
View Profile email_gz email_gz   IP Logged
fonseca.ha
UK
Reply #4 - Feb 2nd, 2008, 10:27am
Hello All,
Does anyone has a reference about CSL. I didn't found what is the when compared to CML.
Cheers,
Humberto
Reply #5 - Feb 26th, 2008, 6:45pm
Last I checked -
CSL is the same as differential CML
If you research ECL (Emitter coupled logic) designs you will find info on ground referenced CML.
(Look around for data on MECL 10,000 - Motorola's old ECL stuff)
That is an old bipolar version of singled ended CML.
THere exist level shift and convert circuits between CSL and vanilla CMOS logic, amplification to recreate a rail to rail logivc level, in essence.
