May 18th, 2024, 5:14am
how to write sequential program using SKILL (Read 3256 times)
rajdeep
UK
Sep 12th, 2007, 3:55am
hi all,
I have been trying to execute a set of skill functions in the CIW. My objective is to run them sequentially,
that is one after another. To do this I'm just writing them in a file in the order I want, and loading that file
in the CIW using load("skillprogram.il").
But I don't think it is executing them sequentially. When I run those skill functions one by one in the CIW it works fine.....
Is there a way to write sequential programs using SKILL??
Plz help
Rajdeep
svenn
Does it have to be
legal?
Re: how to write sequential program using SKILL
Reply #1 - Sep 14th, 2007, 1:29pm
Depends on what skill functions you are running. Try to select all of your skill functions and paste them into CIW instead of one by one and see what happens. If you copy and paste one line after each other, your mouse movement is slow enough for any ipc calls to finish before you manage to get the next function paste.
Svenn
Svenn
haikom
Reply #2 - Sep 17th, 2007, 12:43pm
if you are using SKILL++ (files with the extention .ils), you all command inside the letseq( ... ) statement are executed sequentially. But there are some differences to SKILL (scope of variables, symbol handling). Please check the SKILL Language User Guide chapter 13 (About SKILL++ and SKILL).
Kind regards,
haikom
View Profile haikomo   IP Logged
