Aug 15th, 2024, 6:01pm
Mentor ADVance MS (Read 2516 times)
priya
india
Mentor ADVance MS
Sep 12th, 2007, 10:52am
Dear ALL,
I have just started with Verilog-A.and i tried to run my initial code on Mentor's ADVance MS tool.
I realised i need a command file,a do file.
I have tried simulating the example files supplied with the tool,was able to run them as they had the command files.
I have tried writing my own,but was not able to run.
Can somebody please help me how do i write and where i can find info on command(.cmd) file.
Thanks.
Priya
Paul Floyd
France
Re: Mentor ADVance MS
Reply #1 - Oct 10th, 2007, 1:36am
Hi
Please could you say more precisely what you are trying to do, and the errors that you obtain?
Very briefly, the command file is a spice file. It can be very simple (for instance if your simulation has a 'top' that is Verilog-A(MS)).
The do file is a Tcl script file. You don't need this if you are using vasim in GUI mode (though it will make loading/running the design quicker).
Just a quick example for a Verilog-AMS simulation:
1. Create a library, e.g., "valib WORK"
2. Compile your design, e.g., "valog design.va"
3. Run vasim. The "Compiled HDL" button should be selected for Top Design.
4. Select your Design Unit from the list.
5. For the Command File, click New, and check the Analysis that you want to perform.
6. Click Load.
7. Assuming all has gone well so far, click on the Run All button.
If you still have problems, try contacing Mentor support.
Paul
