Jul 17th, 2024, 6:44pm
Difference Amplifier (Read 3882 times)
magathi
Utah
Sep 12th, 2007, 3:51pm
Iam trying to model a simple difference amplifier....
//Verilog-AMS HDL for "test", "pip_difference_amp" "verilogams"
`include "constants.vams"
`include "disciplines.vams"
module pip_difference_amp (out,pin,nin);
output out;
input pin,nin;
electrical out, pin,nin;
parameter real gain = 1;
parameter real td = 0;
parameter tt = 0;
real diff;
analog begin
     diff = gain*(V(pin)-V(nin));
     V(out)<+transition(diff,td,tt);
This is the error message Iam getting...
ERROR (ADEXL-5012): An error occurred while netlisting the
         testbench on point 1.
Could somebody explain what this error means?
Re: Difference Amplifier
Reply #1 - Sep 12th, 2007, 5:02pm
I don't know what the error message means, but you probably should remove the transition function.
Does the error message even apply to this module, it is referring to "netlisting a testbench"?
magathi
Utah
Reply #2 - Sep 13th, 2007, 12:02pm
Thanks for your help. It was an error generated by the Cadence design environment. as my config file was not generated correctly....
