Oct 5th, 2024, 2:00pm
high speed TTL output with rigorous load problem (Read 3450 times)
Robert
Xiamen city,Fujian PRO. china
Sep 12th, 2007, 6:27pm
hi, guys,
   here i wanna design a TTL output interface circuit, the requirement is shown as following:
1. low logic level <500mV, high logic level = Vcc (offered by the external supply, independent on the chip supply)
2. the load is consisted of a 7.5Kohm pull up resistor parallel with a 20p capacitor.
3. the singal frequency is as higher as 100MHz.
  i have been tried many prototypes, such as open drain、push pull、cherry hooper amplifier, however, non of them can reach the requirements.  do you guys have any other structures or techniques、solutions, please post it, i really need your kindly help, thanks in advance.
best regards
Nio Lin
i am a gay,who loves ppmm!
Re: high speed TTL output with rigorous load probl
Reply #1 - Sep 12th, 2007, 7:50pm
Hi Nio,
Did you define the minimum value of high logic level? Any which spec does your TTL output violates?
Yawei
Robert
Reply #2 - Sep 12th, 2007, 8:33pm
hi, Yawei,
 thanks for your reply, the output high logic level is not exactly required to equal to VCC(external), but we still expect it is not less than Vcc-0.3V.
Best Regards
Nio Lin
Robert
Reply #3 - Sep 13th, 2007, 12:45am
Dear Yawei,
  here the specification of Vcc (external) is in a range of 1.8V to 5.5V.
B.R.
Nio Lin
Reply #4 - Sep 17th, 2007, 1:38am
Hi Nio,
So Vcc-0.3V is your requirement for the minimum high output voltage.  Don't you meet this spec, assume you have pull-up resistor?
Yawei
