Sep 28th, 2024, 7:57am
Transient Noise to build Phasenoise curve (Read 4549 times)
Stefan
Sep 21st, 2007, 2:15pm
has anybody of you used a transient noise simulation to calculate a phasenoise curve for an Oscillator or PLL ?
I know that this is error prone and RF measures would be more appreciated, but in this special case we simply can do only transient simulations.
Anyone has experience with this ?
Stefan
View Profile 16731287   IP Logged
Sarig
Re: Transient Noise to build Phasenoise curve
Reply #1 - Dec 6th, 2007, 10:10am
I have the same problem. did you find the answer ?
Erez
neoflash
Mixed-Signal
Designer
Reply #2 - Dec 16th, 2007, 6:34am
Since phase noise is a random process, it requires very large amount of data to do statistical analysis. So, if you run transient, you make sure you do very long time and have enough of data for jitter analysis.
I don't think it is feasible way.
Sarig
Reply #3 - Dec 17th, 2007, 1:32pm
We need to do Tranisent noise and find the phase noise because for example for Fractional N this is the only why to find the Phase noise.
Also for VerilogA models you need to do many changes i order to run PSS+PNoise.
So if you want you can for PLL-> Down convert to I and Q -> Filter -> bring to Matlab using:
x=I+jQ
find the angel -> unwarp -> fit to line and PSD it.
you are right that you need long long sim (1mS for GHz VCO)
Sarig.
kDaniu
Reply #4 - Apr 30th, 2008, 4:55pm
neoflash wrote on Dec 16th, 2007, 6:34am:
you have to say - How much that your 'for a long time'?
that transient noise in Spectre has a behavior to degenerate (in the case of statistical quality (randomness))
