Aug 17th, 2024, 3:21am
Temperature optimization of BSIM Parameters (Read 4313 times)
Mooraka
Lexington, KY
Sep 22nd, 2007, 5:26pm
I would like to use optimization routine for tweaking BSIM parameters to meet the leakage goals at different temperatures. I looked into optimization procedures supported by Eldo and Hspice and it seems none of them support this (They only support DC/AC/Transient optimization of model parameters).
Can any body suggest me if there is any other way to do this. I know BSIMPRO/ICCAP can do this, but I wonder if any industry standard circuit simulator support this.
AD
simon2
Southampton, United Kingdom.
Re: Temperature optimization of BSIM Parameters
Reply #1 - Sep 23rd, 2007, 12:22pm
Hi Analog Designer,
                            if you know the transfer function, you can write this in a sub-circuit.
Go to your PDK and look at the resistor models - they have probably been written as an equation, they should get you started ...
Cheers,
            SimonH.
Simon.Harpham@ieee.org
http://www.SiliconDevices.com
Mooraka
Lexington, KY
Reply #2 - Oct 5th, 2007, 7:16pm
Thanks. Actually I am looking for temperature optimization for BSIM3 model params. It seems I need to search in the tool manuals for this.
AD
simon2
Reply #3 - Oct 10th, 2007, 4:39am
If it helps ... I came across a paper called "CMOS Transistor Mismatch Model with Temperature Effect for HSPICE and SPECTRE" by Tan, Kordesch and Sidek in the IEEE digital library, if you have access to that.
Cheers, Simon2.
simon2
Reply #4 - Oct 10th, 2007, 4:43am
... also there is a significant amout of information in section 9.2 "Temperature Dependence Models in BSIM3v3" page 265 of Cheng and Hu's "MOSFET Modeling & BSIM3 Users's Guide".
