Aug 17th, 2024, 1:12am
Spectre Model for High Voltage MOS (Read 11579 times)
k-one
Oct 30th, 2007, 8:31am
all,
I need a spectre model for our HV Mos.... what is the industry standard for MOS high voltage model- MM20? EKV-HV?
thanks
Re: Spectre Model for High Voltage MOS
Reply #1 - Oct 30th, 2007, 11:34am
k-one wrote on Oct 30th, 2007, 8:31am:
all,
thanks
The Compact Model Council is expected to vote on a standard by the end of the year.  MM20 is already in the public domain; HV-EKV is another candidate (and I believe its Verilog-A code is available); HiSIM-LDMOS is the third candidate (from Hiroshima University).  HiSIM-LDMOS looks good from the presentations by the Japanese CMC members, but the code is held under non-disclosure agreement (NDA) until/unless it is accepted as the standard.
I'll also mention that spectre has a built-in model (spectre -help hvmos).
k-one
Reply #2 - Oct 31st, 2007, 3:02am
Geoffrey_Coram wrote on Oct 30th, 2007, 11:34am:
all,
thanks
Hi Geoffrey,
Thanks a lot for the info. I did spectre -h and notice that spectre support MM20 through level mos2002. But I didn't see any ekv or hisim High Voltage model listed. Only normal ekv and hisim listed. Is there any other name to represent these 2 high voltage models?
What is the performance of the built in model- hvmos? Also, I noticed there is another one named ldmos model in the list but I am not sure the performance of this model.... do you have any ideas?
Reply #3 - Oct 31st, 2007, 6:51am
k-one wrote on Oct 31st, 2007, 3:02am:
Hi Geoffrey,
I've never used the built-in ldmos nor hvmos.  I also don't believe the HV-EKV or HiSIM-LDMOS models are installed in Spectre, but you might find HV-EKV in Verilog-A that you could run in Spectre.  A "release candidate" (SC1) of HiSIM-LDMOS is in the latest (2007.09) HSpice.
k-one
Reply #4 - Oct 31st, 2007, 5:45pm
Geoffrey_Coram wrote on Oct 31st, 2007, 6:51am:
Hi Geoffrey,
Hi Geoffrey,
Thanks. Looks like MM20 is the best candidate for my HV spectre model. I think Built in model not really good as it is not one of the CMC candidate for HV model.
I have another question. Can this MM20 run with hspice? Currently, we are using level 66 for our hspice HV model. That means I need to extract 2 models for my HV process. Level 66 doesn't support spectre.
Reply #5 - Nov 1st, 2007, 4:28am
k-one wrote on Oct 31st, 2007, 5:45pm:
Hi Geoffrey,
Have you tried using level=66 parameters with Spectre's hvmos?  I may be completely misremembering something, but I thought that perhaps Cadence had licensed it from Synopsys.
MM20 is available in Verilog-A, and this will run in HSpice (assuming you have the VA compiler option with your copy of HSpice).
k-one
Reply #6 - Nov 1st, 2007, 5:57am
Geoffrey_Coram wrote on Nov 1st, 2007, 4:28am:
Hi Geoffrey,
you mean copy parameters from my hspice level 66 into hvmos model and run the simulation... I never try it. But what I know, level 66 is a Synopsys proprietary. Only recently, they allowed ICCAP as a extractor. Before this we need to use Synopsys extractor- Aurora.
Can we directly run MM20 in hspice. Sorry, I don't familiar with verilog-A
thanks
Reply #7 - Nov 1st, 2007, 8:21am
k-one wrote on Nov 1st, 2007, 5:57am:
There's not a level for mm20, but you do something like:
.hdl "mos2002t.va"
x1 d g s b mos2002t vfb=-0.45 vfbd=-0.05
(This syntax is for the Verilog-A in an enhanced Spice3f5, but the syntax in HSpice is *very* similar, and I think they also support .model cards for VA.)
Verilog-A is a behavioral modeling language; you write the equations of the device in the language, and the simulator invokes a compiler and dynamically links the resulting object file.
k-one
Reply #8 - Nov 6th, 2007, 4:03am
Geoffrey_Coram wrote on Nov 1st, 2007, 8:21am:
.hdl "mos2002t.va"
Thanks. We have decided to use MM20 from NXP as our high voltage model for spectre. Thanks a lot for your help.
