DoYouLinux
I am designing a 7 GHz ring oscillator and looking for a good practical way to place dummy transistors for each functional transistor.
As shown in the attached figure, for example, in case that I have a functional transistor having a size of 10/0.18 (5/0.18 with 2 fingers) and I would like to add dummy transistors to this functional transistor. Is it correct that I just add two independent (isolated) transistors, each having a size of 5/0.18 and all terminals are grounded (for NMOS) to both sides of the functional transistor ? Then, as shown in the layout, the distance between the dummy transistors and the functional transistors have to kept as small as possible, right ?
Thank you very much in advance,
DYLinux
