Jul 16th, 2024, 8:27pm
syntax error for string parameter (Read 2941 times)
lily
seattle
Oct 03rd, 2007, 7:35pm
I am trying to use string type parameter in my veriloga model like below, the spectre simulator always complain syntax error. I have checked the spectre veriloga reference, it gives the example  same as mine. Is there anyone know why I cannot use this string parameter?
Thanks!
module INV( in,out,vdd,gnd );
input in,vdd,gnd;
output out;
electrical in,out,vdd,gnd;
parameter real Cin_in1=9.342169858000004E-12 ;
parameter real Cout=1.7384E-14*2 ;
parameter string proc="typ";
Error found by spectre during AHDL read-in.
   "./INV.va", line 15: "parameter string <<--? proc ="typ";"
   "./INV.va", line 15: Error: syntax error
Re: syntax error for string parameter
Reply #1 - Oct 8th, 2007, 4:54am
What version of Spectre are you running?
In some cases, you may be able to simply omit "string" -- I think this makes the parameter an integer type, where the bytes are set by the ascii values of the string literal ("typ"), so you can do some comparisons on it in the module.
lily
seattle
Reply #2 - Oct 11th, 2007, 6:41pm
Thanks for reply. Actually cadence 6.0 supports the string parameter and it seems lower version does not.
//lili
