HdrChopper
Hi cktlife,
Both offset and noise will degrade the converterīs resolution. However, usually offset errors are much larger than thermal noise induced errors due to resistor sizing, as Carl suggested. KT/C noise might eventually be important depending on the C involved and obviously the temperature the circuit works at. If T is large enough, the noise effect might be comparable to the offset contribution to the resolution degradation. I would say the total noise power (within the converterīs bandwidth, and including the offset power) must be less than 1LSB if look for a more comprenhensive definition.
Regards tosei
