May 3rd, 2024, 3:43pm
problem in simulation (Read 8675 times)
rakeshkumar
Oct 09th, 2007, 5:08am
i m using verilogA code for opamp in cadence enviornment
my output is getting saturated
the reason of this i coudn't find
i also want to view the internal node cout
any suggestion plz!!!!!!!!!!!!!!!!!
Stefan
Re: problem in simulation
Reply #1 - Oct 9th, 2007, 5:17am
Hi rakesh(?),
a) your "!" key seems to be stuck.
b) How to judge about your code if you don't provide it ?
c) Think about load.
d) What the heck is cout ?
e) Hello and thank you is good to appear polite.
View Profile 16731287   IP Logged
rakeshkumar
Reply #2 - Oct 9th, 2007, 5:21am
this is my code
'define pi=3.141592
//opamp
//-operaional amplifier
// vin_p, vin_n: differential input voltage[V,A]
// vout        : output voltage[v,A]
// vref        : reference voltage[V,A]
// vspply_p    : positive supply voltage [V,A]
// vspply_n    : negative supply voltage[V,A]
//INSTANCE parameters
// gain=gain[]
// freq_unitygain=unity gain frequency[Hz]
// rin=input resitance[ohms]
// vin_offset=input offset voltage referred to negative[V]
// ibias=input current[A]
// iin_max=maximum current[A]
// slew_rate=slew rate[A/F]
// rout=output resistance[Ohms]
// vsoft=soft output limiting value[V]
MODEL parameters
//{none}
module opamp(vout,vref,vin_p,vin_n,vspply_p,vspply_n);
     (gain,freq_unitygain,rin,vin_offset,ibias,imax,
                                     slew_rate,rout,vsoft)
node[V,I] vout, vref,vin_p,vin_n,vspply_p,vspply_n;
parameter real gain=835e3;
parameter real freq_unitygain=1e6;
parameter real rin=1e6;
parameter real vin_offset=0;
parameter real ibias=0;
parameter real iin_max=100e-6;
parameter real rsrc=0.5e6;
parameter real rout=80;
parameter real vsoft=0.5;
real c1;
real gm_nom;
real r1;
real vmax_in;
real vin_val;
node[V,I] cout;
initial{
c1=iin_max/(slew_rate);
gm_nom=2*pi*frq_unitygain*c1;
r1=gain/gm_nom;
vmax_in=iin_max/gm_nom;
analog
        vin_val=V(vin_p,vin_n)+vin_offset;
        //Input stage.
           I(vin_p,vin_n)<- (V(vin_p,vin_n)+vin_offset)/rin;
           I(vref,vin_p)<- ibias;
           I(vref,vin_n)<- ibias;
        //GM stage with slewing
           I(vref,cout)<-V(vref,cout)/100e6;
           if(vin_val>vmax_in)
               I(vref,cout)<- iin_max;
           else if(vin_val< -vmax_in)
               I(vref,cout)<- -iin_max;
           else
               I(vref,cout)<- gm_nom*vin_val;
        //  Dominant Pole.
           I(cout,vref)<-ddt(c1*V(cout,vref));
           I(cout,vref)<-V(cout,vref)/r1;
        //Output stage.
           I(vref,vout) <- V(cout,vref)/rout;
           I(vout,vref) <- V(vout,vref)/rout
        //Soft Output Limiting.
           if (V(vout)>(V(vspply_p)-vsoft))
               I(cout,vref)<- gm_nom*(V(vout,vspply_p)+vsoft);
           else if(V(vout)<(V(vspply_n)+vsoft))
               I(cout,vref)<- gm_nom*(V(vout,vspply_n)-vsoft);
Reply #3 - Oct 9th, 2007, 6:15am
rakeshkumar wrote on Oct 9th, 2007, 5:21am:
this is my code
'define pi=3.141592
That's silly.  Just use `M_PI from constants.h
I'm not familiar with that notation.  I'm expecting to see
 inout vout, vref,vin_p,vin_n,vspply_p,vspply_n;
 electrical vout, vref,vin_p,vin_n,vspply_p,vspply_n;
and then you can just add "cout" to the lists of pins.
Actually, reviewing the code further: you're not using Verilog-A.  You've got {} instead of begin/end; you've got "<-" where I expect "<+".
Also, your "initial" should probably be coded inside the analog block (as @initial_step -- or not, most compilers are smart about it now); otherwise, some simulators may tell you that the variables assigned there are digital variables and may not let you use them elsewhere.
The last time someone on this forum had a problem with the op-amp, it turned out that the supply pins weren't connected properly.
rakeshkumar
Reply #4 - Oct 9th, 2007, 7:21am
this is my verolog-A code
'define pi=3.141592
//opamp
// gain=gain[]
// rsrc=source resistance[A/F]
MODEL parameters
//{none}
input vref,vspply_p,vspply_n;
inout vout,vin_p,vin_n;
electrical vout,vref,vin_p,vin_n,vspply_p,vspply_n;
real c1;
real gm_nom;
real r1;
real vmax_in;
real vin_val;
electrical cout;
analog begin
@(initial step or initial_step("dc")) begin
c1=iin_max/(rsrc);
r1=gain/gm_nom;
///Input stage.
I(vin_p,vin_n)<+(V(vin_p,vin_n)+vin_offset)/rin;
I(vref,vin_p)<+ibias;
I(vref,vin_n)<+ibias;
I(vref,cout)<+V(vref,cout)/100e6;
if(vin_val>vmax_in)
 I(vref,cout)<+iin_max;
 I(vref,cout)<+-iin_max;
else
I(vref,cout)<+gm_nom*vin_val;
//  Dominant Pole.
I(cout,vref)<+ddt(c1*V(cout,vref));
I(cout,vref)<+V(cout,vref)/r1;
 I(cout,vref)<+gm_nom*(V(vout,vspply_p)+vsoft);
 I(cout,vref)<+gm_nom*(V(vout,vspply_n)-vsoft);
during simulation
this is in-built code
i m dealing with macromodel so i m using it
Reply #5 - Oct 9th, 2007, 9:48am
You should try sanity checks like: tie both inputs to ground, make sure you get 0 out.
Your VA code is missing the output stage that was shown in the original (non-VA) code.  In your VA code, I see V(vout) being probed, but I don't see any contributions to vout, neither current nor voltage.
raveendras4a5
Reply #6 - Feb 21st, 2012, 8:43pm
Hi Geoffrey_coram,
I am also trying to Behaviorial Modeling of Op-Amp. I have simulated the above Code, I am getting output.
But, I didn't understand where is that "cout" node comes into picture. & I couldn't able to get exact behavioral mode diagram for the above code..
Actually I need to design the 2 input & 2 output differential Amplifier. So, How Can I modify the above code to get 2 differential Outputs.
raveendras4a5
Reply #7 - Feb 21st, 2012, 10:13pm
Hi Rakeshkumar,
Do you have the Behavioral model of the above program??
I tried to extract the behavioral view of this program but couldnot able to do that. If you know pls let me know too.
Where did you get this programm.? At lrast tell me that one.
boe
Reply #8 - Feb 23rd, 2012, 8:37am
It seems that in the Verilog-A version of the code the output stage is missing, which is included in the first HDL model.
- B O E
