Jul 21st, 2024, 12:25pm
ams simulation: how to use this file which includes all views of the cells (Read 2478 times)
xuedashun
Jan 26th, 2012, 9:16am
I have a digital block which uses many logic gates. All of the gates are in
one of my libraries, but there are only symbol views and no verilog views
there.
The verilog views of all of the logic gates are in one file. I don't know how
to import the views to individual cells. Is it possible to just use this single
file for the gates to run the ams simulation?
Thank you!
topquark
Thames Valley, UK
Re: ams simulation: how to use this file which includes all views of the cells
Reply #1 - Feb 13th, 2012, 5:24am
Hi there,
I assume you're using Virtuoso?
In which case, there's a good Cadence tutorial (not available in public domain, search it on cadence support website) on how to set up config views for AMS sims.
If I'm right, what you're looking for is something like shown in the attached pic.
Open your adexl test editor:
Go to Simulation> Options > AMS Simulator
In that window:
Include paths - should point to the directory which has all your verilog views
Similarly, specify lib files (foundry libs)
Let me know how you got on?
