Jul 16th, 2024, 10:58am
What are these error from LVS: psub_StampErrorMult (Read 164 times)
DoYouLinux
Oct 16th, 2007, 8:01am
I tried to run LVS, but I had found the following error messages:
psub_StampErrorMult
psub_StampErrorConnect
Can they be neglected or do we need to set some thing in LVS window (I use Assura) ?
HdrChopper
Re: What are these error from LVS: psub_StampError
Reply #1 - Oct 17th, 2007, 8:49pm
I guess these are substrate contacts connected to different nets. That is why is telling you there are multiple stamped connections.
You need to correct this error by looking (most probably) a short between the GND line and some other net.
Hope this helps
Tosei
Keep it simple
bernd
Munich/Germany
Reply #2 - Oct 18th, 2007, 8:36am
In most of the chip design cases you have more than one ground
net connected to substrate e.g. you have a digital and an analog ground
on your chip. In reality these net might be connect over substrate,
but for Assura LVS these nets have different net names, so it's a kind
of a short over the substrate for the LVS.
Therefore most of the design kits come with a dummy layer to isolate
one part or more parts of the substrate for the LVS, have a look for it.
Or otherwise all your nets connected to substrate should have the same name.
Bernd
Just another lonesome cad guy
