Aug 15th, 2024, 2:39am
What are these error from LVS: psub_StampErrorMult (Read 2918 times)
DoYouLinux
Oct 16th, 2007, 11:41am
I tried to run LVS, but I had found the following error messages:
psub_StampErrorMult
psub_StampErrorConnect
Can they be neglected or do we need to set some thing in LVS window (I use Assura) ?
didac
There's a million
ways to see the
things in life
manresa,spain
Re: What are these error from LVS: psub_StampError
Reply #1 - Oct 17th, 2007, 9:06am
Have you checked that you have contacts to the p_substrate and to the nwells?,and if you are doing a custom layout check that nwells exists around the transistors.
Hope it helps,
