Monkeybad
How to transform a serial RGB analog signal to parallel analog signals? The RGB analog signal spec is ENOB=8bit, 10MEG at least. The purpose of the question I ask is I want to save three DACs into one DAC. Generally, the current steering video DAC can operate in high frequency like 100MEG. So, is there a circuit to do this transformation? Like use "one high frequency DAC+Sample and hold" to replace "three DACs"?
