dash82
I completely modified my code. I guess i am facing one final glitch. I think my logic is correct for 1/2 rate Convolutional Encoder with generator polynomials (1,1,1) & (1,0,1). However, I see a race condition.
I am using "reset" variable to control the set of statements that gets executed. However, I am seeing that all the assignment statements are getting executed everytime, irrespective of the "reset" variable condition.
I want to make my code synthesizable too. Any help would be greatly appreciated. Please excuse me if this question annoys you. Still learning.
module conencoder (out1,out2,in1,clock,reset); output out1,out2; input in1,clock,reset; reg u0,u1,u2,temp_u0,temp_u1,temp_u2; reg out1,out2; initial begin //if (reset) //begin assign out1 = 1'b0; assign out2 = 1'b0; assign u0 = 1'b0; assign u1 = 1'b0; assign u2 = 1'b0; assign temp_u0 = 1'b0; assign temp_u1 = 1'b0; assign temp_u2 = 1'b0; //end end always @(clock) begin if (reset) begin //shifting the input bit through 3 registers. assign u2 = temp_u1; assign u1 = temp_u0; assign u0 = in1 ; end else if (!reset) begin //performing xor operation to produce the encoded bits. ERROR:All assignment statements are getting //executed irrespective of "reset" variable block checking. assign out1 = (u2 ^ u1 ^ u0); assign out2 = (u2 ^ u0); assign temp_u1 = u1 ; assign temp_u0 = u0 ; end end endmodule -------------------------------------------------------------------------------- -------- testbench: --------------
module testbench ; reg clock,reset,in1 = 1'b0;
conencoder r1(out1,out2,in1,clock,reset);
initial begin //clock = 1'b1; //reset = 1'b1; end
/*always begin // #30 clock = ~clock ; end */
always begin #3 reset = 1'b1 ; #2 in1 = 1'b1; #3 clock = 1'b1 ; #3 reset = 1'b0; #3 clock = 1'b0; //ERROR STARTS. After this all assignment statements seems to be getting executed in main code. #3 reset = 1'b1 ; #2 in1 = 1'b1; #3 clock = 1'b1 ; #3 reset = 1'b0; #3 clock = 1'b0; #3 reset = 1'b1 ; #2 in1 = 1'b1; #3 clock = 1'b1 ; #3 reset = 1'b0; #3 clock = 1'b0; #3 reset = 1'b1 ; #2 in1 = 1'b1; #3 clock = 1'b1 ; #3 reset = 1'b0; #3 clock = 1'b0; #3 reset = 1'b1 ; #2 in1 = 1'b1; #3 clock = 1'b1 ; #3 reset = 1'b0; #3 clock = 1'b0; end endmodule
The above code is compiled with ModelSim and works fine. I know I am making some stupid mistake due to which all 'assignment' statements are getting executed in the main code. Please help and I apologize for a long description.
